  3. Any Way to identify double hits (Via)?
  • Replies 36
  • Subscribers 171
  • Views 53896
Alice
Alice over 17 years ago
If  on the same net DRC, due to the stack via design. Alot of DRC will apply also.
Is there a way to identify this issue? Pls advice.
Alice
  • Romme
    Romme over 17 years ago +1
    Wouldn't it be easyer to setup drc rules to accept stacked via 's ?
  • Alice
    Alice over 17 years ago +1
    My problem is how to detect 2 same via overlap each other but has slight different xy position at same layer? These 2 vias have same net. So, if I on the same net drc, I will get alot of drcs.
  • Alice
  • Geoff
    Geoff over 17 years ago
    Incredible program Dave. I have found it useful already.
    Our boards have alot of Ground stitching which could result in duplicates if you are not paying attention.
  • DE202408202727
    DE202408202727 over 17 years ago
    OK,
    Thanks for this and other feedback.
    I'll put it together into a small Skill utility with a form - and a few other enhancements - and publish next week.
    Cheers, Dave
  • Marathon
    Marathon over 17 years ago
    Hi Dave,
    I was wrong in my original thought on reporting only the pins/vias that are on a net only. The whole purpose is to show ALL the multiple drill hits regardless of being on a net or not. This way the fab shops can make adjustment to their drill setup from the report. As Geoff noted, it is an incredible program and extremely useful in eliminating questions from the fab shops regarding the mutliple drill hits.
  • DE202408202727
    Ok,
    As promised, attached is the utility. Thanks to those who provided input and feedback - especially Marathon.
    ;  Installation instructions:
    ; Install findDoubleHitHoles_public.il into your skill folder.
    ; Add load("findDoubleHitHoles_public.il") to the allegro.ilinit file in your pcbenv folder.
    ;  Running within Allegro:
    ; Type "find double hits" (without the speech marks) in the command window.
    As always, feedback is welcome.
    Regards, Dave
  • DE202408202727
    Ok, (my last post got lost)
    Regards, Dave
    findDoubleHitHoles_public.zip
