  3. Any Way to identify double hits (Via)?
  • Replies 36
  • Subscribers 171
  • Views 53903
Alice
Alice over 17 years ago
If  on the same net DRC, due to the stack via design. Alot of DRC will apply also.
Is there a way to identify this issue? Pls advice.
Alice
  • Romme
    Romme over 17 years ago +1
    Wouldn't it be easyer to setup drc rules to accept stacked via 's ?
  • Alice
    Alice over 17 years ago +1
    My problem is how to detect 2 same via overlap each other but has slight different xy position at same layer? These 2 vias have same net. So, if I on the same net drc, I will get alot of drcs.
  • Alice
  • steve
    steve over 17 years ago
    Dave
    Can you please attach this as a zip file ?
    Cheers Steve
    Edited - Don't worry it worked the second time I tried..... Sorry
  • DE202408202727
    DE202408202727 over 17 years ago
    Hi Steve,
    See my second post (on the next page).
    Cheers, Dave
    This email, including any attachments, is only for the intended addressee. It is subject to copyright, confidential and may be the subject of legal or other privilege, none of which is waived or lost by reason of this transmission. If the receiver is not the intended addressee, please accept our apologies, notify us by return, delete all copies and perform no other act on the email. Unfortunately, we cannot warrant that the email has not been altered or corrupted during transmission.
  • ahmetozsoy
    ahmetozsoy over 17 years ago
    Hi Dave,
    I couldn't get the zip file . Could you please upload it or directly send it to my e-mail address.
    Best regards
    Ahmet OZSOY
  • DE202408202727
    Right click on the attachment and select "save target as" to save it.
  • Gxer
    Gxer over 14 years ago
    can you add a delete tab to remove double via at the same xy?
