  3. Any Way to identify double hits (Via)?
  • Replies 36
  • Subscribers 171
  • Views 53909
Alice
Alice over 17 years ago
If  on the same net DRC, due to the stack via design. Alot of DRC will apply also.
Is there a way to identify this issue? Pls advice.
Alice
  • Romme
    Romme over 17 years ago +1
    Wouldn't it be easyer to setup drc rules to accept stacked via 's ?
  • Alice
    Alice over 17 years ago +1
    My problem is how to detect 2 same via overlap each other but has slight different xy position at same layer? These 2 vias have same net. So, if I on the same net drc, I will get alot of drcs.
  • Alice
  • DE202408202727
    DE202408202727 over 14 years ago
    Hi, Please try the attached context file. Place it in your Skill path and add the following lines in your allegro.ilinit file: loadContext("findDoubleHitHoles_public.cxt") axlCmdRegister("find double hits" 'FDH_findDoubleHitHoles) Type "find double hits" in the console window to run it. Please let me know if you have any problems. Cheers, Dave
    findDoubleHitHoles_public.zip
  • Gxer
    Gxer over 14 years ago
    Hi! I have this error in command window: "E- *Error* toplevel: undefined variable - FDH_findDoubleHitHoles"
  • DE202408202727
    It should work. Try putting the context file in your working folder. and typing the following command in your console window: skill loadContext("findDoubleHitHoles_public.cxt") axlCmdRegister("find double hits" 'FDH_findDoubleHitHoles)
  • Gxer
    Now it's ok!! Thanks a lot!!!
  • odanoy
    odanoy over 13 years ago
    Dave,
    What would you recommend for duplicate pins? We have many designs where we need to have overlapping components for alternate population options (for example one build will use heatsink A and another build will use heatsink B and both heatsinks must be placed in the same XY location in Allegro) which mean overlapping through hole pins which we also need to "remove". So far we have modified your findDoubleHitHoles_public.il code to replace one of the duplicate pins by a "null padstack" (padstack with no drill or shapes) but was wondering if you or anyone else had a better idea on how to deal with this issue? Delete the pins? Move the pins
    Olivier
