  3. Any Way to identify double hits (Via)?
  • Replies 36
  • Subscribers 171
  • Views 53917
Alice
Alice over 17 years ago
If  on the same net DRC, due to the stack via design. Alot of DRC will apply also.
Is there a way to identify this issue? Pls advice.
Alice
  • Romme
    Romme over 17 years ago +1
    Wouldn't it be easyer to setup drc rules to accept stacked via 's ?
  • Alice
    Alice over 17 years ago +1
    My problem is how to detect 2 same via overlap each other but has slight different xy position at same layer? These 2 vias have same net. So, if I on the same net drc, I will get alot of drcs.
  • Alice
  • DE202408202727
    DE202408202727 over 13 years ago
    Hi Olivier,
    I can't think of a better way than the method you are using. An alternative is to waive the drc and notify your fabricator.
    Cheers,
    Dave
  • odanoy
    odanoy over 13 years ago
     Thanks Dave. Yes that's what we've been doing until now. Waive the DRCs and get the fab shop to remove the duplicate holes.
     Olivier
  • B Bruekers
    B Bruekers over 12 years ago
    Hi Dave,
    thanks for this utility!  A delete option would be nice to have :)
    Some issues:
    - the 'external DRC' buttons are not enabled, but the external DRCs are generated.
    - When I click on the 'X' of the form Allegro crashes.  (16.6.S029). This happens everytime.
    The exit button works fine though.
    I've also tried the normal .il file and the context file, both generate the same crash.
  • DE202408202727
    DE202408202727 over 12 years ago
    Try the attached... (16.6 only)
    Use  loadContext to load the file and register the command using axlCmdRegister("find double hits" 'FDH_findDoubleHitHoles)
    Dave
    findDoubleHitHoles_public.zip
  • Helen
    Helen over 12 years ago
    dbdoctor can Eliminate duplicate vias.
    CM will prevent overlapping vias.
