  3. Any Way to identify double hits (Via)?
  • Replies 36
  • Subscribers 171
  • Views 53923
Alice
Alice over 17 years ago
If  on the same net DRC, due to the stack via design. Alot of DRC will apply also.
Is there a way to identify this issue? Pls advice.
Alice
  • Romme
    Romme over 17 years ago +1
    Wouldn't it be easyer to setup drc rules to accept stacked via 's ?
  • Alice
    Alice over 17 years ago +1
    My problem is how to detect 2 same via overlap each other but has slight different xy position at same layer? These 2 vias have same net. So, if I on the same net drc, I will get alot of drcs.
  • Alice
  • masamasa
    masamasa over 7 years ago in reply to DE202408202727
    hello dave
    thank you for sharing the file
    i have tried to use findDoubleHitHoles_public.il but it does not detect duplicated vias (padstacks).
    does the holes mean vias or padstacks?
  • DE202408202727
    DE202408202727 over 7 years ago in reply to masamasa
    It's checking holes in pins and vias that are in the same, or nearly the same, position and the start-end layers of the holes are the same.
  • RFinley
    RFinley over 7 years ago in reply to DE202408202727
    I'm having trouble as Allegro PA3100 16.6 SP115:
    W- *WARNING* context read failure: can't read 64-bit context on 32-bit platform
    E- *Error* loadContext: context I/O failed - "findDoubleHitHoles_public.cxt"
    Starting new design...
    17p2 s061 gives me:
    *Error* loadContext: could not open file - "64bit/findDoubleHitHoles_public.cxt"
  • RFinley
    I need to keep 16.6 running until Mentor Graphics updates their translator to Expedition/P*DS to deal with the padstack changes, etc.
  • RFinley
    RFinley over 7 years ago in reply to RFinley
    Sorry about the 17.2 question.  I found that my 64bit folder copy of the cxt file didn't go through.  Now it works.
    Does anyone have a 32-bit cxt file that works for 16.6?
