  3. Delete Shape Objects
  • Views 19216
PherricOxide
PherricOxide over 16 years ago
Hello, I'm trying to delete some auto generated shapes on a layer. dbDeleteObject and axlDeleteObject both give me the error,
W-  Cannot delete element type: Shape(auto-generated) "I17_Ch_Gnd, Etch/Lay17_Gnd-.3".
Is there some other command to do this?
  • Alice 2009
    Alice 2009 over 16 years ago
    Is the shape auto generated which the object is "Figure". If so, I think you will need to select the "Figure" object to delete it. I am not sure will it works, but you may try.
     Good luck =)
  • rong96
    rong96 over 16 years ago
    You need to select the boundary to delete it, instead of the shape itself. Using the shape dbid you can get the shapeBoundary attribute and use that with axlDeleteObject.
