  3. Cancelling axlSingleSelectPoint() ??
  • Replies 7
  • Subscribers 159
  • Views 14944
jwhend
jwhend over 11 years ago
 Hi all,
I want to cancel a axlSingleSelectPoint() command if the user decided not to finish. I there a way to cancel axlSingleSelectPoint()?
Jerry
  • seyerfred
    seyerfred over 11 years ago
    did you already try to add this in your code?
    mypopup = axlUIPopupDefine( nil
    (list (list "Done" 'axlFinishEnterFun)
    (list "Cancel" 'axlCancelEnterFun)))
    axlUIPopupSet( mypopup)
  • jwhend
     I'm doing this from a form field.The program create voids and etch for test coupons, where each layer has a different pattern.
    If the user decides to exit after selecting a box, I want to be able to kill the axlSingleSelectPoint, if I can.
    The user selects a checkbox and then selects a component(axlSingleSelectPoint) :
            coupon_symbol=car(axlGetSelSet())
            coupon_rotation=float(coupon_symbol->rotation)
            coupon_x=car( coupon_symbol->xy)
            coupon_y=cadr( coupon_symbol->xy)
    The issue I am having is that if the user decide not to pick a component and exit out the procedures continues to the end, or fails.
    My callback looks like this:
     procedure(_callback(form_status)
    let((newbox numFields)
        cond(
            (form_status->curField=="cancel"
            axlCancelEnterFun()
            axlUIWUpdate(nil)
            axlFormClose(form_status)
            deleteFile("./DC_Reg_Coupon.form")
            (form_status->curField=="Reset"
            numFields=form_status->fields
            axlClearSelSet()
                foreach(Field numFields
                axlFormColorize(form_status Field 'background nil)
                axlFormSetField(form_status Field nil)
            (integerp(atoi(form_status->curField))
            newbox=atoi(form_status->curField)
            PCD_ceCreatePathTables(newbox)
            axlFormColorize(form_status form_status->curField 'background 'green)
            axlClearSelSet()
    Jerry
  • eDave
    eDave over 11 years ago
    Hi Jerry,
    I would use a variable to control this:
    form_status->continue = nil
    form_status->continue = axlSingleSelectPoint()
        cond(
            (form_status->curField=="cancel" || !form_status ->continue
  • jwhend
     Hi Dave,
    Where do I add form_status->continue=nil?
    I tried to add it above the  form_status->continue = axlSingleSelectPoint(), but it closes the form when I select a button.
     Also, this is a global variable, correct?
    Jerry
    eDave said:
    Hi Jerry,
        cond(
  • eDave
    Sorry, I put you wrong. Initialise it to t.
    It's not global because it's an attribute of the form variable. Of course I have assumed that your form variable is form_status and you may well have used something else..
