  2. PCell Designer
  3. Locating PCell Designer
  • Subscribers 9
  • Views 6910
dandadom
dandadom over 2 years ago
I'm quite new to Cadence and I recently started a research position in my university related to analog design. Because I am expected to self start it's been a little difficult to navigate Cadence, and to do my work I need to use PCell Designer. Unfortunately I cannot locate it, is it a separate GUI? or is it integrated in another tool? I can see PCell in my Tools dropdown, but as far as I know that brings me to the mostly depreciated graphical PCell window, and a place to write SKILL code.
I would really appreciate some help to get started, Thank you!
Dominik
    Andrew Beckett over 2 years ago +1
    Dominik, You would need to download the PCD25 (latest hotfix) release from http://downloads.cadence.com and there's a video on installing it here: Installing Cadence PCell Designer (you'll also find…
    0 Andrew Beckett over 2 years ago
    Dominik,
    You would need to download the PCD25 (latest hotfix) release from http://downloads.cadence.com and there's a video on installing it here: Installing Cadence PCell Designer (you'll also find other videos in the channel on the right hand side with that link which give introductions).
    There's a couple of rapid adoption kits too:
    • Generating a Layout Parameterized Cell using PCell Designer - Basic
    • Generating a Schematic Parameterized Cell using PCell Designer
    Plus the reference manual can be found in the Custom IC Design section of the Product Manuals page.
  • dandadom
    0 dandadom over 2 years ago in reply to Andrew Beckett
    Thank you Andrew,
    I appreciate the help!
