  2. PCell Designer
  3. Pcell Designer Geo Query land is identifying para shape...
  • Subscribers 9
  • Views 5667
Pcell Designer Geo Query land is identifying para shapes
EMaz
EMaz over 2 years ago
I am seeing unexpected results with the land Geo Query operator. It is recognizing layers that are defined in the para group as if they are actually present in the pcell.
elements involved = 1 group, 1 layer, 1 para instance
1) Group: gRouteSigNorth contains metals and vias - see pic - it does not contain MET1
2) Layer: MET1 which can be seen in blue in the picture above. MET1 and is part of a group called gTile, (the donut shapes) and the dut in the center (2 small blocks)
3) para instances: I have several groups which are defined in the para group which also contain MET1. In the para group they are defined in quadrant 1 with origin at 0:0
Question: When I select layer MET1, why is the MET from the para shape highlighted? The red outline below shows the MET1 identified from para instances.
The resulting land gives me two shapes... would like to only have the shape on the top.
Thank you!
    0 Andrew Beckett over 2 years ago
    This is (for better or worse - I sometimes wish that we'd changed it in the past, but there's too much risk of it breaking PCells that depend upon the behaviour) the default behaviour of the layer Geo Query when used at the leaf level. In the documentation for the operator, it says:
    The body of the geo operator, otherwise all shapes in all levels of hierarchy, including para shapes.
    If you want to omit the para shapes, you could put the shapes operator inside the layer operator. The will restrict it to just the shapes in the current cellView and omit the para shapes. Note, the shapes operator doesn't include shapes down through the hierarchy, if you wanted the first part of the layer operator's behaviour (i.e. all levels of hierarchy), then you could do:
    layer ("MET1" "drawing")
    -- hierarchy (0 32)
    ---- shapes
    Hope that's clear (let me know if it's not!). This comes up rather often, so I'll get a note added to the layer operator to include these approaches.
  • EMaz
    0 EMaz over 2 years ago in reply to Andrew Beckett
    Thanks Andrew
    Much appreciated.
    Erika
