  2. PCell Designer
  3. How to set-up a schematic.PCell that maestro can select...
  • Subscribers 9
  • Views 4361
How to set-up a schematic.PCell that maestro can select which corners to simulate?
CBuerzele
CBuerzele over 2 years ago
Hi,  with PCellDesigner I created a low  schematic PCell where I want to use corner parameters for simulation.
Currently the Designer have to change the instantiated PCell manually to use the other corner parameters. And the designers prefer to do it via maestro as they are used by other devices.
Thanks for your help!
    0 Andrew Beckett over 2 years ago
    I moved this into the PCell Designer forum (since we have a dedicated forum for it!).
    I don't quite understand how changing corners impacts a schematic PCell. Can you provide more detail?
    Perhaps it would be simplest for you to show me - since we know each other, could you email me directly? I can have a screen-sharing session this afternoon.
