  2. RAVEL DRC Programming for IC Packaging and…
  3. Constants defined n Ravel?
  • Subscribers 23
  • Views 18798
Martin Biehl
Martin Biehl over 13 years ago
Is there a way to define constants in Ravel? I have some numbers that I would like to define in one place for use in the code. They are not constraints so I do not want to define them as such since that would make it possible to change the values.
  • Bjoern L
    Bjoern L over 13 years ago
    Martin,
    You can use macros to define constants. Simply define a macro of no arguments returning the constant value. To retrieve the value, call the macro. Here is an example:
    (macro PI () 3.141593)
    (define edge_circumference
      (transform (e) circular_edge
        (e 2 * (PI) * (radius e))))
     Kind regards, Björn
  • Martin Biehl
    Thanks Bjoern for your quick reply.
    Kind Regards,
    Martin
