  2. RAVEL DRC Programming for IC Packaging and…
  3. How to Automate (batch) the Ravel run from Constraint M...
  • Subscribers 23
  • Views 20447
How to Automate (batch) the Ravel run from Constraint Manager
AlexeyG
AlexeyG over 12 years ago
Is there a way to run ravel from Constraint Manager in a batch mode (for example for the regression test needs) ?
Thanks in advance,
Alexey.
  • Bjoern L
    Bjoern L over 12 years ago
    Hello Alexey,
    to import a rules file or control file and analyze rules from it, you can use the following sequence of commands:
    cmgr
    setwindow cmgr
    cm import ravel ReadRelationalDRCFile rules.ravc
    cm analyze ( Design "the_design" ) RELA_FOO 0
    cm analyze ( Design "the_design" ) RELA_BAR 0
    The RELA_ names are the CM attributes of the corresponding Ravel rules. You can discover them either in the journal file after interactively analyzing a rule, or in the tooltip you get when you hover the mouse over the "# Violations" table header in the worksheet of the rule. This works in -nographic mode too.
    Björn
  • AlexeyG
    Hello Bjoern,
    I just tried what you suggested and it worked perfectly for me.
    Thanks again for your great support !!!
