  2. RAVEL DRC Programming for IC Packaging and…
  3. How do I get a line's Angle?
  • Subscribers 23
  • Views 15704
Rian
Rian over 11 years ago
How to you get at the angle of a line in Ravel land? Here's a snapshot of what I am after. We need to make sure the line is around 30 degrees. i.e. Between MIN=29.9 and MAX=30.1
  • KMani
    KMani over 11 years ago
    You can find the angle using 'axis_angle' measurement.
    (axis_angle object1 object2) => Measures the smallest angle (in degrees) between the objects.
  • Bjoern L
    Bjoern L over 11 years ago
    There are a couple of different measurements for working with angles, depending on which angle you are looking for. The angle measurement returns the counter-clockwise angle between two linear objects in the range [0, 360]. The principal_value measurement can be used to normalize this angle to the range [-180, 180]. There is also axis_angle, which treats two linear objects as directionless axes and returns the smallest angle between them, which is going to be in the range [0, 90].
    I was not familiar with this "normalized" segment angle displayed in the Show Element window, but it seems to be the counter-clockwise angle within the quadrant from x or y coordinate axis to the segment. This angle will be the same regardless of segment direction, it will just shift the quadrant. If we have the angle from a unit vector [1, 0] to the segment, the normalized angle na can be expressed as a mod 90, or the reminder after dividing a with 90. Like in many programming languages, mod only works on integer numbers in Ravel, so we will have to express this a bit more convoluted as na = a - 90(floor(a/90)).
    Suppose that you have a relation mysegment with the segments that you want to check. You could then find this angle by:
    (define mysegment_angle
      (transform (s) mysegment
        (s (angle (CREATE_VECTOR 1 0) s))))
    (define mysgement_normalized
      (transform (s a) mysegment_angle
        (s a - 90.0*(floor a/90.0))))
    You would then subtract this from your constraint value and compare the absolute value with some epsilon.
  • Rian
    Thanks for the help.  What is this (CREATE_VECTOR) function above?  I thought maybe it was built-in until I got:
        E- *Error* No such derivation or measurement create_vector
    Can you "draw" a new line with some make line or vector function?
         (makeLine (start_point myLine),  (point  (xcoordinate myLine + 100), (ycoordinate myLine)) )
    So the same starting point as the trace line but add 100 to the X (and the same Y of course so it is horizontal) and then use the angle function with those 2 lines?
    My email is rchipman @ micron .com if you need the .SIP file or just want to get in touch. Thanks, Rian
  • Kirti Sikri
    Kirti Sikri over 11 years ago
    Hello
    CREATE_VECTOR is in the Ravel Standard Library.
    Purpose: Create a vector from the origin to the given coordinates. Syntax (CREATE_VECTOR x/number y/number) => vector/vector
    If you don't have RSLYou can add this before your code.
    (macro CREATE_VECTOR (X Y)
    "CREATE_VECTOR x/number y/number => vector/vector
    Create a vector from the origin to the given coordinates."
    (connecting_line (create_point 0.0 0.0) (create_point X Y)))
    Kirti
  • Rian
    Thanks. Turned out just the angle function and that "normalized" principal_value function did the trick (which is good because I never could get that CREATE_VECTOR to work). Here's the complete code:
    (constraint MIN_ANGLE 29.9)
    (constraint MAX_ANGLE 30.1)
    (define PlatingTrace
      (select (mLine) line
        (and
          (layer? mLine, "SUBSTRATE GEOMETRY/UNITBOT_PLTG_RT") ; RT = Routed
          (length mLine) < 10000.0 ; Exclude main vertical line segment
    ; Go 1000 out on the X axis but same Y axis so it is horizontal
    ; Yes end_point is the end of the line next to the middle vertical line
    (define BadAngles
      (select (mLine, mAngle)
        (transform (mLine) PlatingTrace
          (mLine, (abs (principal_value (angle mLine, (connecting_line (end_point mLine), (create_point 1000.0           (ycoordinate (end_point mLine))))))))
         (or ; angle must be between 29.9 and 30.1 so errors are outside this range < 29.9 OR > 30.1
          (mAngle < (value MIN_ANGLE))
          (mAngle > (value MAX_ANGLE))
