  2. RAVEL DRC Programming for IC Packaging and…
  3. How to check the <NAME> of a line?
  • Subscribers 23
  • Views 6372
Rian
Rian over 11 years ago
How do I check the < NAME > name of line?  Is there a line_refdes like component_refdes? Something like:
(define PlatingTrace
    (select (mPlatingTrace) line
       (ZZZZZZ_refdes? mPlatingTrace "HORIZONTAL LINE SEGMENT"))
       (layer? mPlatingTrace "SUBSTRATE GEOMETRY/UNITBOT_PLTG_PU")
THANKS, RIAN
  • Bjoern L
    Bjoern L over 11 years ago
    Hi Rian,
    that is not a name, but rather a description. A segment can be described as horizontal, vertical, odd-angle or arc. In Ravel, you can find if a segment is horizontal by seeing if it is parallel to a horizontal unit vector:
    (axis_angle segment (CREATE_VECTOR 1 0)) < 1.0
    In my previous post I forgot to mention that CREATE_VECTOR is a macro in standard/geometry in Ravel Standard Library. To create a vector without using the standard library, you would do:
    (connecting_line (create_point 0 0) (create_point 1 0))
    Björn
