  2. RAVEL DRC Programming for IC Packaging and…
  3. How do I search Symbols by name?
  • Subscribers 23
  • Views 21997
Rian
Rian over 11 years ago
Our diagrams should have certain "mechanical" symbols but Ravel does not have a "symbol" built-in relation. I know it has a shape relation but this does not have a component_name?
I guess the easy question is how do I find this iron man fiducial?...
Here's the code that fails:
(define FiducialIM
    (select (mSymbol) shape  ; NO symbols relation :(
        component_name?(mSymbol, "IRON_MAN_BOC")
P.S. I am told by the designers we can't make these symbols components because they are mechanical only.
  • Bjoern L
    Bjoern L over 11 years ago
    Hi Rian,
    The design database distinguishes between symbols which are physical and components which are logical. Ravel objects are always physical, and you will find all symbols in the 'component' relation, which correspond to the physical parts placed in the design. There is a range of predicates to tell the type of a component, in particular 'mechanical?' will return true for mechanical components.
    Björn
  • Rian
    This returns nothing though:
    (define FiducialIM
        (select (mSymbol) component
            mechanical?(mSymbol)
    (report (mSymbol) FiducialIM
     ("All Components ~A" mSymbol, boundary(mSymbol))
    In fact if I report all component (I just replace mechanical? above with 1==1 :) I get a whooping 1:
    All Components #<symbol:DIE> (((3120.5 4340.0) (-3369.5 4340.0)) ((3120.5 -3340.0) (3120.5 4340.0)) ((-3369.5 4340.0) (-3369.5 -3340.0)) ((-3369.5 -3340.0) (3120.5 -3340.0)))
    Here's another image from Cadence if it helps...
