  2. RAVEL DRC Programming for IC Packaging and…
  3. How to define ballpads
  • Subscribers 23
  • Views 20245
Nealb
Nealb over 11 years ago
We would like to write some Ravel programming to measure solder ball to package edge and I am unable to define ballpad and obtain a relation. Is there somehow to do this?
  • KMani
    KMani over 11 years ago
    Hi Neal,
    you can get all the ballpads from the Ravel predefined relation "ballpad".
    Please refer Ravel Manual section 4 for all the ravel predefined relations
    http://support.cadence.com/wps/myportal/cos/!ut/p/a0/RcmxDoIwEIDhZ3FgpYTFxKaDibM6MCjbUU9puF7LXUvi28vm9n_5zWgeZmTYwgdKSAy0-_lCzBR4iYFPA_r5XqdL8mpVvMt1UitICIpXiOjsvmpELsM3o4vAFUjt6ppOYEMSfP-rb_tj090yCpQk2s4lkjV5OR9-1q5nlA!!/
    here is sample code which measures the distance between component and ballpad
    (select (ball_pad comp dist)
            (transform (ball_pad comp) (combine ballpad component)
                (ball_pad comp (distance (center ball_pad) comp))
        (dist < (value MIN_SPACING))
