  2. RAVEL DRC Programming for IC Packaging and…
  3. Setup RAVEL
  • Subscribers 23
  • Views 29498
Setup RAVEL
comet
comet over 9 years ago
Hi Guys,
I couldn't run RAVEL under Allegro PCB Designer Manufacture tab. It prompted "Environment Variable DFM_RAV_PATH is not set. Please set it to the correct path and try again."
Please let me know how.
Thanks!  ;-)
  • BinduSripad
    BinduSripad over 9 years ago
    Please set your DFM_RAV_PATH to c:/cadence/spb_17.2/share/pcb/dfm_ravel or c:/cadence/spb_16.6/share/pcb/dfm_ravel (based on where your Cadence installation folder is) and try again.
    Bindu
  • comet
    Hi Bindu, where and how can I set the DFM_RAV_PATH?
  • BinduSripad
    Please type the following in your Allegro Command Window (assuming you are using Allegro 17.2 and Cadence installation directory is c:/cadence):
    set dfm-rav_path c:/cadence/spb_17.2/share/pcb/dfm_ravel
    Bindu
  • BinduSripad
    Correction:
    Please type
    setup dfm_rav_path c:/cadence/spb_17.2/share/pcb/dfm_ravel
  • comet
    Oh yeah, i checked my env and the DFM_RAV_PATH wasn't called. I had used an old file. Thanks again. ;-)
