  2. RF Design
  3. sp modelling of differential amplifier
  • Subscribers 65
  • Views 23379
aaamin
aaamin over 17 years ago
 I need to extract s parameters of a differential linear equalizer (high pass filter) using spectre.
I do not have spectre RF.  How do I do four port analysis?
  • Jim McMahon
    Jim McMahon over 17 years ago
    Assuming you want basic differential and not mixed-mode S-parameters, then you can attach a  "balun" component (from the "rfLib" library)  to both the differential input and output of your amplifer. One would then attach a "port" component (from the "analogLib") library to single-ended terminals of the balun. The port should configured with the correct impedance (e.g 50Ohms) and assigned a port number (1 and 2). Depending on your design you may also need to add DC blocking and biasing to the amplifier inputs, etc.
     The "rfLib " library is available in the cadence installation directory: $CDS_INSTALL_DIR/tools/dfII/samples/artist/rfLib
     You should now be ready to simulate the design in spectre using ADE. Setup an "sp" analysis and sweep over the desired frequencies. After the simulation completes, select "Results->Direct Plot->Main Form..." You can also use the calculator to plot S12.
    You may also want to check the RF Design Forum for addition help and suggestions.
     Jim
  • aaamin
     Jim,
    Thank you for pointing to right direction. The challenge is that I do not have rfLib.
    So I tried to create balun using two xfmr elements. But cant define rout and rin of balun.
    I am not sure what port impedance to use. Considering the ckt as blakcbox, how do I select
    port imepdance?
  • Jim McMahon
    You should also be able to get it to work using the xfrm. The port impedance can be set by changing the port resistance parameter. The default is 50Ohms.
     Jim
  • Frank Wiedmann
    Frank Wiedmann over 17 years ago
    For the ideal balun, take a look at http://www.designers-guide.org/Analysis/diff.pdf.
  • Babak7
    Babak7 over 7 years ago in reply to aaamin
    Transformer impedance is related to the square of turn ratio.  Say you have a transformer with turn ratio of 1:n  That is the primary is 1 times and the secondary is n times of turns.  Now say you connect the secondary to say Zout  Then the impedance seen from primary is Zout/SQR(n)  and if you connect the primary to Zin the output impedance seen by the output connection is:
    Zin/SQR(1/n)
    or
    Zin X SQR(n) = Zin X n^2
    SQRT(Zin/Zout) =1/n
    or
    Zin/Zout =SQR(1/n)= (1/n)^2
    Babak
