  2. RF Design
  3. ADE TOOLS-RF-Wizard (is dark, not selectable)
  • Subscribers 63
  • Views 15357
RFMEMS
RFMEMS over 17 years ago
I was trying to using the new noise-aware PLL design flow feature, but the ADE TOOLS-RF-Wizard is dark and not selectable.
I am using IC 5.10.41.500.6.133 and MMSIM71-0.060.
 Does anyone know how can I make the RF wizard work?  Thanks in advance!
    Andrew Beckett over 17 years ago
    Do you have <MMSIM71>/tools/bin in your UNIX path, and if so, is the "tools" link present in the MMSIM71 installation root?
    (I assume you mean that Tools->RF->PLL ? If the menus are different from this, perhaps you have a local customized spectre.menus file which is messing things up?)
  • RFMEMS
     Thanks Andrew, finally I solved the problem, you are right, it is the local customized spectre.menus which caused trouble.
