  2. RF Design
  3. How do you sweep under ADE-XL Monte Carlo simulation.
  • Subscribers 64
  • Views 15782
Spirito
Spirito over 17 years ago
I am new in ADE-XL , and I tried to simulate a mixer's conversion gain over a range of IF frequency. it all runs well in ADE-L
My variables are IF=1G , RF=6*IF and LO=5*IF . I then sweep in pss the IF from 0.8G to 1.2G and get a gain curve. From which I calculate the maximum and the ripple (max-min), using to output expressions. However, when I export this to  ADE-XL the sweep doesn't work since the IF variables value is set by the global variable. and If I sweep using the global variable then : A. I cannot calculate the maximum gain or ripple automatically . B. I cannot run MC with the sweep on.
 Any Ideas ?
Spirito
  • alanw
    alanw over 17 years ago
     Hi Spirito,
     I believe that currently an OCEAN measurement is required to do this. Something like:
                axlAddOutputs( '( "maxGain" "gainRipple"))   /* Define the output labels to be used in ADE-XL */
                fif_sweep = sweepVarValues("fif" ?result "pss_fd") /* Get the list of IF freq sweep values */
                frf_sweep = list()   /* Initialize a list of RF freq sweep values */
                /* Create list of RF freq sweep values, RF=6*IF relationship needs to be re-defined here */
                for(i 1 length(fif_sweep)
                    frf_sweep = append(frf_sweep list(nthelem(i fif_sweep)*6))
                gain_sweep = list()   /* Initialize  a list of gain measurements */
                for(i 1 length(fif_sweep) /* For all the IF freq sweep values */
                         fif_value = nthelem(i fif_sweep)   /* Get the IF freq */
                         frf_value = nthelem(i frf_sweep)  /* Get the corresponding RF freq */
                         /* Calculate the gain */
                        gain_sweep = append(gain_sweep list(mag(value(famValue(v("/RFout" ?result "pss_fd") fif_value) fif_value) /
        value(famValue(v("/RFin" ?result "pss_fd") fif_value) frf_value)) ) )
                xv = drCreateVec('double fif_sweep)   /* X-axis - the IF freq sweep points */
                yv = drCreateVec('double gain_sweep) /* Y-axis - the conversion gain values */
                wave = drCreateWaveform(xv yv)  /* Create a conversion gain waveform - can plot this */
                axlOutputResult(ymax(wave) "maxGain")  /* Export max gain measurement */
                axlOutputResult(ymax(wave)-ymin(wave) "gainRipple") /* Export gain ripple measurement */
    One caveat though - when you run Monte Carlo in ADE-XL, turn off "Save Data to Allow Family Plots". When that's enabled, you need additional indexing to pull the measurement value off of an individual conversion gain waveform.
    In the ADE-XL test editor,  under Outputs->Setup, set Measure Type to OCEAN and then point to a file containing a script similar to above.
     Alan
