  2. RF Design
  3. Questions about IC613 installation on RHEL5
  • Subscribers 64
  • Views 16432
tjjbraye
tjjbraye over 17 years ago
Hi buddy,
I installed IC613 in the RHEL5.4 32bit platform.But when I run virtuoso,it can't startup and gives "segmentation fault" errer infomation.I found later RHEL5 64bit platform is only supported officially.How could I run IC613 in RHEL5 with 32bit while some other application softwares are needed in 32bit platform ?
Here is the CDS.log file contents when run the command : virtuoso:
\o Program:              @(#)$CDS: virtuoso version 6.1.3 07/09/2009 05:00 (cic612lnx) $
\o Hierarchy:             /media/edatools/cadence/ic613/tools.lnx86/dfII/
\o Sub version:         sub-version IC6.1.3.500.12b (32-bit addresses)
\o Host name (type):       localhost.localdomain (i686)
\o Operating system:      Linux 2.6.18-164.el5 #1 SMP Tue Aug 18 15:51:54 EDT 2009
\o X display name (WxH):      :0.0 (1680x1050)
\o Available geometry:                 TL(0:25) BR(1679:1024)
\o X server:        The X.Org Foundation
\o Depth of Visual (Root):     24 (24)
\o Number of Planes Used:   24
\o X version:             11.0 (vendor release 70101000)
\o X resource pool:  base 0x1d00000, mask 0xfffff (1048575), shift 0
\o                current id 0x6f, current max 0xffffa (1048570)
\o Qt version:            4.2.3
\o Window Manager:       gnome (metacity)
\o User Name:           tjj
\o Working Directory:     localhost.localdomain:/home/tjj/cadence
\o Process Id:            31220
\o
\o COPYRIGHT © 1992-2009  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
\o           © 1992-2009  UNIX SYSTEMS Laboratories INC.,
\o                          Reproduced with permission.
\o
\o This Cadence Design Systems program and online documentation are
\o proprietary/confidential information and may be disclosed/used only
\o as authorized in a license agreement controlling such use and disclosure.
\o
\o           RESTRICTED RIGHTS NOTICE (SHORT FORM)
\o Use/reproduction/disclosure is subject to restriction
\o set forth at FAR 1252.227-19 or its equivalent.
\o Loading geView.cxt
\o Loading schView.cxt
\o Loading selectSv.cxt
\o Loading LVS.cxt
\o Loading layerProc.cxt
\o Loading xlUI.cxt
\o Loading auCore.cxt
\o Loading vhdl.cxt
\o Loading seismic.cxt
\o Loading ci.cxt
\o (dbPanic) dumping stack
\o dbPanic+292()
\o voDoAbortFuncs+37()
\o voSigAbort+46()
\o /media/edatools/cadence/ic613/tools/QT/lib/libQtCore.so.4/PLT+504204()
\o ilxSkillEval2+205()
\o iliLoadPort+1386()
\o ilfLoadi+87()
\o iliVcodeEval2+25175()
\o _ilTopLevelSet+357()
\o ilxTopLevelCmd+376()
\o ilTopLevelCmd+38()
\o ilLoadCapContext+1107()
\o iliInitClients+995()
\o main+430()
Thanks very much in advance!
  • tjjbraye
    Finally I changed to the subversion IC6131 (update release ,not hot fixs)and succeeded installing it on RHEL5 Thanks anyway
  • Bo Zhao
    Bo Zhao over 17 years ago
    Hi, you just installed a newer version and the problem gone? No other modifications?
    I met the same problem and I tried to copy the Cadence Virtuoso from our server, which is in a slightly order version, but it gave me the same problem.
    Do you have any idea why this happens? Following is the content of my CDS.log file. Thanks.
    \o Program:        @(#)$CDS: virtuoso version 6.1.3 09/08/2008 02:56 (cic612lnx) $
    \o Hierarchy:        /usr/local/cad/cadence/ic610/tools.lnx86/dfII/
    \o Sub version:        sub-version IC6.1.3.1 (32-bit addresses)
    \o Host name (type):    ZhaoBo (x86_64)
    \o Operating system:    Linux 2.6.18-128.1.1.el5 #1 SMP Mon Jan 26 13:58:24 EST 2009
    \o X display name (WxH):    :0.0 (1920x1200)
    \o Available geometry:            TL(0:25) BR(1919:1174)
    \o User Name:        root
    \o Working Directory:    ZhaoBo:/root/cdstry
    \o Process Id:        18546
    \o
    \o COPYRIGHT © 1992-2008  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
    \o           © 1992-2008  UNIX SYSTEMS Laboratories INC.,
    \o
    \o
    \o dbPanic+203()
    \o voSigAbort+46()
    \o /cad/cadence/ic610/tools/lib/libihdlGrUtils.so/PLT+134741708()
    \o smnWrMsgDiscard+37()
    \o smniWrStrmClose+34()
    \o smnStreamClose+76()
    \o smanExport+72()
    \o mpsAnnounceService+122()
    \o mpsiExportService+883()
    \o mpsExport+138()
    \o useItcInit+1350()
    \o spSecureInit+186()
    \o iliInitClients+882()
    \o main+419()
  • tjjbraye
    in fact,I don't know what happened exactly I just changed to the update release version IC6131 and RHEL5 x86_64 for it is officially fupported.
  • tkhan
    tkhan over 16 years ago
     Was this problem resolved? My colleauge and I are getting a similar problem but in fc10 using IC613 and more recently IC614. I made a post about it recently:
    http://www.cadence.com/community/forums/T/14119.aspx
     My network admin has installed RHEL4 and I'm gonna test it out tomorrow.
