  2. RF Design
  3. pss+pnoise analysis failure in Monte Carlo Simulation
  • Subscribers 62
  • Views 3555
Soner
Soner over 16 years ago
I am trying to run a Monte Carlo simulation of a 25GHz LC-VCO (vco followed by an ac-coupled buffer) for phase noise (mmsim-7.11, pss (harmonic balance) and pnoise). When I try a single run (no variability), the simulation finishes successfully without any errors or warnings. When I try running a Monte Carlo simulation (with process and mismatch), I am having one of the problems described below randomly (depending on the seed and starting run#). By the way,  when I try to run a transient analysis in a Monte Carlo simulation with the same samples, the simulation finishes successfully. Could you please help?
1) After the first few samples, the simulator stops/freezes without any error messages in the output log.
2) At the first sample, I got the error message: "ERROR SPECTRE-16192: No convergence achieved with the minimum time step specified". I think this happens during the tstab. However the transient simulation does not have any convergence problems with the same set of samples.
  • Tawna
    Tawna over 16 years ago
    Hi SonerYaldiz,
    You didn't mention what subversion of MMSIM 7.1.1 you were using.  If you are simulating with BSIMSOI devices, there is a known issue that is described in support.cadence.com Solution 11588618 which is fixed in the latest MMSIM 7.1.1 ISR available on downloads.cadence.com .
    If the latest ISR doesn't resolve this issue, I recommend contacting Cadence Customer Support and filing a Service Request, attaching your spectre output logfile to the SR.
    best regards,
    Tawna Wilsey
  • Soner
    Hi Tawna,
    The latest ISR resolved the issue.
    Thanks and regards,
    Soner Yaldiz
