  2. RF Design
  3. Oscillator Phase Noise with SpectreRF
  • Subscribers 62
  • Views 16439
archive over 16 years ago
On p416 of the SpectreRF User guide, there is a plot of the phase noise vs. frequency for an oscillator in dBc/Hz. The phase noise at close in frequencies to the carrier has a value greater than 0 - I am wondering why is this the case? Or perhaps another way to ask this would be how does spectreRf measure the carrier amplitude to scale the phase noise plots in dBc/Hz. Thank you in advance. -Vijay
  • Tawna
    Tawna over 16 years ago
    Hi Vijay095,
    This is discussed in depth in Cadence Online Support Solution
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=1832229
    Essentially, values above 0dBc/Hz should be discarded.
    best regards,
    Tawna
    Hi Tawna, Thanks very much! Best regards, -Vijay
