  2. RF Design
  3. Noise simulation in Complex filter
  • Subscribers 63
  • Views 16223
Megh
Megh over 16 years ago
Cadence recommends following way to do the noise simulation in Complex filters: -
According to principle of superposition noise can be calculated as follows:
1. Calculate output noise (V**2/Hz) when only portI is active:
- at Iout: Ioutn_I(f);
- at Qout: Qoutn_I(f).
2. Now calculate output noise (V**2/Hz) when only portQ is active:
- at Iout: Ioutn_Q(f);
- at Qout: Qoutn_Qf).
Now you can calculate the total otput noise (V**2/Hz) at both outputs:
Ioutn(f) = Ioutn_I(f) + Ioutn_Q(f);
Qoutn(f) = Qoutn_I(f) + Qoutn_Q(f);
______________________________________________________________________________
The complex BPF is made of 2 LPFs. Both of them have gain = 0dB. Also Gain is 0dB for complex out to complex input.
Now I see that input referred noise is double that of output referred noise even though gain is 0dB .  I don't know why this is happening. Please help.
Megh
  • Tawna
    Tawna over 16 years ago
     Hi Megh,
    You don't say what type of noise analysis you are running.... Is this ac noise, spectreRF pnoise, etc. ?
    For a summary of existing noise documentation, you may want to take a look at:
    Summary of existing documentation on various RF related noise analyses
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11585972
    (I suspect that you may be referring to COS Solution  11162588 .   You may want to consider filing a Service Request so that a Support AE can assist you in greater detail.)
    best regards,
    Tawna
  • Megh
    Hello Tawna,
    Thanks for replying. I am performing AC Noise analysis.
    Please let me know what do you think on the stated problem.
    I will file an SR on this.
    Meghraj
