  2. RF Design
  3. av_extracted-schematic discrepency
  • Subscribers 63
  • Views 14364
rfdude
rfdude over 16 years ago
 Hello all
I have designed a mixer in 130nm technology and I have done the LVS for the circuit and as a result, schematic and layout match. I am doing post layout simulation to compare the results of the extracted version with schematic. For conversion gain, S-parameters and interception points the results are fine but, Noise figures are different.
In schematic simulations, 1/f noise is much lower (20 dB) from the extracted version. It only happens for 1/f noise!
I have done the noise setup according to SpectreRF_Mixer533AN.pdf from cadence.
 Can anyone give some hint if I have to consider something for proper 1/f simulation?
