  2. RF Design
  3. SP-Simulation : GPC Option
  • Subscribers 63
  • Views 16951
bVenu
bVenu over 16 years ago
I have a question about how to interpret the power gain circles plotted using Spectre's SP analysis
For plotting the power gain circles on the Z-smith chart , there are 2 options: Frequency and Gain Level
 Suppose I select sweep  "Gain level"  Start = 5dB , Stop = 20dB , step = 5
In my circuit, input port = 50-ohms , output port = 500-ohms.
  Will this sweep the value of the output port impedance and create circle with all the points where the power gain is the same?Are the values that we read off the smith chart are output reflection coefficients? Are they normalised to the input port or output port resistance?
 Is there any technote/tutorial that explains how to use the different 'Main-Form" options in the SP analysis?
Venu
  • Tawna
    Tawna over 16 years ago
     Hi Venu,
    Please check out the appendix D of the SpectreRF User guide.  The appendix is called: Plotting Spectre S-parameter Simulation Data
     http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=pubs;q=/spectreRFvol2/spectreRFvol27.1.1/appD.html
    You may also want to check out the example:  LNA Design Using SpectreRF AppNote
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=wp;q=ApplicationNotes/Custom_IC_Design/LNA_62_appnote.pdf
    Best regards,
    Tawna
  • bVenu
    Hi Tawna,
    Thanks a ton! Great pointers.
    At the University we have a complete Cadence Installation, could you tell me where I can find the schematic for the differential amplifier described that LNA design spectre RF note (LNA_62_appnote). In case it comes with the installation, there must be some standard path I can search
    It is not present in the rfExample directory @   $CDS/tools/dfII/samples/artist/rfExamples
    rfExamples only has a single ended BJT based LNA circuit.
    best
    Venu
  • Tawna
     Hi Venu,
    I recommend looking in the hierarchy at:
    <mmsim>/tools/spectre/examples/SpectreRF_Workshop
    In the directory, there are appNotes there, as well as workshops - one in particular on LNAs.
    For more information, please see my blog post from February 2009:
    "Shhhh....SpectreRF Tutorials and Appnotes - One of our best kept secrets!"
     http://www.cadence.com/Community/blogs/rf/archive/2009/02/09/shhhhh-spectrerf-tutorials-and-appnotes-one-of-our-best-kept-secrets.aspx
    Good luck and have fun!
     best regards,
    Tawna
