  2. RF Design
  3. Using ADE calculator with SP Analysis
  • Subscribers 63
  • Views 16627
bVenu
bVenu over 16 years ago
Could I get some inputs on how to use the result of the s-parameter analysis in Spectre to do post processing in either WaveScan or AWD? I need to use the s-paramter or y-parameter data to compute this large expression
{I Y12 - Y21 | ^2}   /  {4*{(Re(Y11)*Re(Y22) - Re(Y12)*Re(Y21)}}
If computing this in Spectre is not easy, Is there a way to maybe print out the Y-parameters and just process them in matlab instead?
Venu
  • bVenu
     I figured out how to print the data into ocean for post processing in a earlier post on this forum
     http://www.cadence.com/community/forums/T/10561.aspx
     Any inputs on using the calculator for this would be welcome though!
     cheers!
    Venu
  • Tawna
    Tawna over 16 years ago
    Hi Venu,
     I recommend looking at the Wavescan (IC 5.1.41) or ViVA (IC 6.1.4)user guides.
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=pubs;q=/wavescanug/wavescanug5.1.41/wavescanugTOC.html
    Best regards,
    Tawna
