  2. RF Design
  3. Problem with Assura QRC
  • Subscribers 64
  • Views 16288
RoAm
RoAm over 15 years ago
I'm running QRC (EXT91) for parasitic extraction. In the beggining it says ' no technology directory found ' after closing that in vuiProtectCall says:
' Error in User Defined procedure "vuiUserDefinedRCXFormSetupCB" Do you want to ignore this error and continue? '
And after running QRC, it gives me this error:
*WARNING* dbOpenCellViewByType: must specify either libName or contextId.
*WARNING* Failed to open (  av_extracted)
INFO (LBRCXU-111): Warning /apps/cadence/ASSURA317_Linux_USR2/tools/assura/bin/rcxToDfII exit with bad status
Does anyone know what is the problem?
  • berndf
    berndf over 15 years ago
     Maybe SourceLink Solution 11146598 helps on this.
    Bernd
  • RoAm
     Thanks Bernd,
     I just got the solution file, I will try it.
  • sanjaybagaria
    sanjaybagaria over 8 years ago
    How can i find this source link solution 11146598 in the community forum?
    I am new to this forum..
    I am facing similar kind of warning
    *WARNING* Failed to build VDB. Cannot submit DRC Run.
    The solution mentioned by Bernd is no longer published (not sure why) but it's unlikely to help because it's about the warning about the technology information being missing in QRC.
    Yours is coming (I assume) from Assura DRC, so is unlikely to be related.
    How are you invoking DRC? From within virtuoso? From the command line? Which version of Assura are you using?
  • sanjaybagaria
    Yeah...the warning coming from Assura DRC when i run the assura and i am invoking assura from virtuoso.
    version of assura i am using is mentioned in release info pdf as "Assura 4.1_USR2_HF6"
    I didn't find any similar reports with Assura DRC (of that precise error) and it's not obvious from the description as to why this should happen. Please contact customer support so that we can investigate further.
    Kind Regards,
