  2. RF Design
  3. not able to run the spectre new version from cadence ADE...
  • Subscribers 63
  • Views 1207
not able to run the spectre new version from cadence ADE/ocean
kumarsatish
kumarsatish over 16 years ago
I installed new spectre version -MMSIM 7.2.0.243-isr7. But the cadence is not running the new spectre version simulator. Please help.
Satish
    Hi Satish,
    Details please. Very hard to debug with so little info:
    1. What IC subversion are you using?
    2. Do you have the path to MMSIM before the path to IC in your UNIX path?
    3. What does "which spectre" give?
    4. What does "spectre -W" give?
    5. How does it fail - does spectre run, and is just running the wrong version? Or is it failing altogether.
