  2. RF Design
  3. CST Microwave: Horn antenna
  • Subscribers 63
  • Views 15530
volvic
volvic over 16 years ago
Hallo everybody
I’m new to CST Microwave and I just trying to know better about it. I am constructing a horn antenna on a brick with a certain angle (a). The think is I would like to connect the filled horn antenna on a brick shape, and the horn antenna most touch the brick with 20 degree cut (a 20 degree most be cut on the horn antenna ) so my problem is how to put  the port on the antenna with 20 degree angle.
Please could somebody help me to fix that problem?
Looking to get propositions from you I remain
Regards
    Whilst these forums are for design as well as tool questions, you would probably be better off asking a question about a specific (non-Cadence) tool elsewhere. Maybe CST have some forums for their own tools (CST is nothing to do with Cadence). Of course, you might get lucky and find someone here who can answer your question... but you're more likely to be successful if you post in a more appropriate place.
    Best  Regards,
