  2. RF Design
  3. rf-pcb module
  • Subscribers 63
  • Views 15297
rf-pcb module
burke39
burke39 over 16 years ago
setting up rules for rf-pcb.if rules are not coming from schematic capture.
    I can't personally answer questions on RF PCB, but it would almost certainly be better if you actually asked a question. There is no question in your post.
  • burke39
    we currently have design involving rf circuits .schematic was done in orcad.We are trying  to use the rf-pcb option in allegro.We are not getting the setup parameters for the rf circuit like you would normally get from concept to use rf-pcb seemlessly.Is there way to setup parameters at the allegro layout stage in rf-pcb to use its routing tools so we can import into ADS.Or would it be better to do the special rf routing in ADS software and import the parameters from ads iff file into rf-pcb to do add to rest of design,and the parameters from ads will be in rf-pcb to do any tweaking of the rf circuit when it is imported to the allegro .brd .
