  2. RF Design
  3. ADXL - running command line sims
  • Subscribers 63
  • Views 1678
RajeshZ
RajeshZ over 16 years ago
When I run log sims, I would like to run initial short sim through ADXL. I would then like to run the long simulation from command line (for example earlier days - you could just ./runSimulation ). The sims typically take a couple of days to complete. I would like to then load the data back in ADXL session to see the results. I understand that viva can be used to view the results standalone. I would like the results to be loaded in ADXL for connectivity.
Can this be done? I tried doing runSimulation but the data is not loaded in the ADXL session. We tried ocean script method also. It doesn't work either for ADXL.
 IC 6.1.4
    Rajesh,
    The supported way to do this is to create an OCEAN script via File->Create Script and then run that. The results can then be looked at using the history in ADE XL.
    Running "runSimulation" was never intended to be used for this in ADE L; it works in some cases, but not all.
