  2. RF Design
  3. About noise-aware PLL design flow
  • Subscribers 63
  • Views 15502
sriram123
sriram123 over 16 years ago
I started the noise aware PLL design flow using cadence 5.141ISR and MMSIM7.1 spectre. When I run PSS on my PFD/CP bench, it gives me an error saying
FATAL(CMI-2010): Assertion failed in file 'check.c' at line 499.
FATAL(SPECTRE-21):Assertion failed.
Please help me identify the problem.
Sriram Muralidharan
  • Tawna
    Tawna over 16 years ago
    Hi Sriram,
    On possible reason (although I saw this on older versions...not 7.1):
    Check your vsource statements.  Do they all have a dc value set?
    If they do not, you will see this error.
    If you put a dc value on the vsource, the error will go away.
     I recommend upgrading to MMSIM 7.2 (latest ISR), as this issue may go away with a newer version of spectre.  Otherwise, please contact Cadence Customer Support.
    best regards,
    Tawna
  • markushschulz
    markushschulz over 15 years ago
    Hi Tawna,
    I have the same problems like Sriram. I tried to set up a PFD/CP simulation with the 'Noise Aware PLL Flow'. I inserted my own PFD/CP circuit into the testbench and set up a PSS and PNOISE simulation. For the oscillation sources I just set up a rectangular signal with a frequency of 25 MHz.
    I dont know where the error comes from. Can you or someone else help me?
    Thanx in advance
    Markus
