  2. RF Design
  3. Problem in transient analysis
  • Subscribers 62
  • Views 15120
Analog Design
Analog Design over 15 years ago
Hi............,
              when I am simulating more complex multiple modules(combining total connection)      , before completation of simulation ,it is stopped and showing error no space for device . Can help me regarding solution of this error .
    Giving the precise error message (and version you're using) would make this rather easier to provide advice on.
    From what you've said, it sounds as if your disk has filled up or quota exceeded, so probably you need to save less, or clean up some disk space.
    But that's just a guess - more precise info would allow a more precise answer.
    Best Regards,
