  2. RF Design
  3. Problem in opening Cadence frm terminal
  • Subscribers 64
  • Views 20454
Analog Design
Analog Design over 15 years ago
 Hi...;
        By opening cadence icfb & , It could not be opened and getting error message like below
[mudassar@vlsi58 ~]$ csh
[mudassar@vlsi58 ~]$ source cadence.cshrc
[mudassar@vlsi58 ~]$ icfb &
[1] 4263
[mudassar@vlsi58 ~]$ *WARNING* file /home/mudassar/CDS.log fflush failed. No space left on device
*WARNING* file /home/mudassar/CDS.log.1 fflush failed. No space left on device
*WARNING* file /home/mudassar/CDS.log.2 fflush failed. No space left on device
*WARNING* file /home/mudassar/CDS.log.3 fflush failed. No space left on device
*WARNING* file /home/mudassar/CDS.log.4 fflush failed. No space left on device
*WARNING* file /home/mudassar/CDS.log.5 fflush failed. No space left on device
*WARNING* file /home/mudassar/CDS.log.6 fflush failed. No space left on device
*WARNING* file /home/mudassar/CDS.log.7 fflush failed. No space left on device
*WARNING* file /home/mudassar/CDS.log.8 fflush failed. No space left on device
*WARNING* file /home/mudassar/CDS.log.9 fflush failed. No space left on device
Failed to lock log file: /home/mudassar/CDS.log.9
How to overcome this problem . If any1 help me I will be thank full .
    You have filled up the disk or exceeded your disk quota. The same is true in the personal message you sent me.
  • Analog Design
    Hi Andrew ,
    Thanks for ur help . Yes ur right.
  • Ankit19
    Ankit19 over 12 years ago
    I am facing same problem. Please help me in getting rid of this problem. I want to know which file should I delete in order to get rid of this warning"disk quota exceeded".
    Ankit
    You are joking, I assume?
    I nearly wrote "sudo rm -rf /*" but decided that would be irresponsible of me...
    Seriously though, if you have filled up your disk quota, it's because you've created too much data. Nobody in this forum can possibly know what you have created or how big it is, or what you should delete. There are numerous UNIX commands to allow you to look at disk usage (including the "du" command) and there are also graphical file browsers in window managers such as KDE and Gnome for those who don't know the UNIX command line commands...
  • Ankit19
    Thanks for your valuable advise. I am able to see CDS.log file of large sizes. Can I delete those files without affecting other files?
    Below is the screenshot of files. Kindly let me know which of the following files can i delete.
    Ankit
