  2. RF Design
  3. Error in HB analysis Setup
  • Subscribers 63
  • Views 15038
bVenu
bVenu over 15 years ago
I am using Cadence Spectre (Version : IC6.1.3.500.13). I am working through the examples in the SpectreRF_Workshop available at  <mmsim>/tools/spectre/examples/SpectreRF_Workshop
 All the Labs have 2 ADE sessions, one using PSS and the other HB. The PSS based simulations work fine but when I run HB analysis, I keep getting the following error :
'hb is an instance of an undefined model hb'
All other analysis (PSS,PAC,AC,DC...) work fine in the testbench, but whenever I want to do anything based on harmonic balance (HB,HBAC, HBNOISE) I see this problem.
Has anyone faced a similar problem? Is there a fix for this?
Thanks.
    You must be using too old a version of spectre. The "hb" analysis was added in MMSIM71, so you'll need to be using a version of spectre from MMSIM71, MMSIM72 or MMSIM101.
