  2. RF Design
  3. new IC614 installation very very slow
  • Subscribers 63
  • Views 16548
wighou
wighou over 15 years ago
I have a serious problem to reinstall IC614. When I needed to use virtuoso after several monthes without activity, its start-up was really really slow. I decided to remove and reinstall the software using InstallScape. But there is a problem. The installation is very slow, maybe blocked now (now, total time elapsed : 80h ; total time remaining : 25h). There is no error but I think I will have to cancel it. This is the case for all computers of microelectronic lab. We use CentOS 5.6. Someone has any idea of the problem ?
Regards
wighou
  • Tawna
    Tawna over 15 years ago
     Hi Wighou,
     You may want to contact Cadence Customer Support about the issue with installScape.   There's really not enough information to tell what is happening.
    A couple of notes.....
    CentOS is not a formally supported operating system for Cadence tools (so you may run into issues there).  The supported platforms are listed on Cadence Online Support at:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=wp;q
    =ProductInformation/LifeCycle/platform.html
    Note that you will need a Cadence login and password.  If you are a university account, you'll need to talk to the staff at the university to see who the Cadence contact is there at your location.
    You will also need to run 'checkSysConf IC6.1.4' to make sure  you have the necessary patches installed on your system to successfully run the software.   <cds>/tools/bin/checkSysConf
    best regards,
    Tawna
  • wighou
     Hello Tawna
    After reaching 140h of installation timeand 90% of installation complete, I forgave. There is no error but something is wrong. I installed the new version of installscape, downloaded the new version of IC610 with the same problem again.
    I will contact the support but, before, I would like to know if anyone had the same problem.
    best regards
    I've not seen other reports of this so that's why we're advising contacting customer support - so some investigation as to why this is happening for you can be undertaken.
  • Tawna
    Hi Wighou,
    I agree with Andrew.  Please contact Cadence Customer Support.
    best regards,
    Tawna
