  2. RF Design
  3. rfline,singlewire,coupledwire
  • Subscribers 63
  • Views 1161
peter450
peter450 over 15 years ago
I'm using cadence spectre for simulation of a circuit. I need a transmission model in the design. I got three models rflin,singlewire and coupledwire.My question is in what applications I can use these three models?
  • Tawna
    Tawna over 15 years ago
     Hi Peter450,
    I recommend using the mtline (or if you have s-parameter data, the nport).  There is the mtline appNote on Cadence Online Support http://support.cadence.com.
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=wp;q=ApplicationNotes/Custom_IC_Design/mtlineAN.pdf
    Also, I recommend looking at the following Solution:
    Use caution when using mtline w/significant skin effect and dielectric loss at high frequencies
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11684156
    You must be a Cadence customer to access these.
    best regards,
    Tawna
