  2. RF Design
  3. IC 614 installation issue
  • Subscribers 62
  • Views 7795
FormerMember
FormerMember over 15 years ago
Hi Folks,
 I'm trying to install IC 614 on RHEL 6 (I've tried also with CentOS 6.0 and I exactly have the same problem) but it is getting a nightmare.
I'm able to install all the packages (IC, MMSIM, Assura and LCU) correctly using inscape.
I'm able to set-up the license server and to make the lmgrd process running (the same workstation is running the license and also the software).
I create a user environment and set all the variables according to an initialization file I've taken from a woking IC 5 installation.
I do the following:
1. change shell to tcsh
2. source initfile
3. virtuoso
At this point I get the following error:
 error while loading shared libraries: libdl.so.2: cannot open shared object file: No such file or directory
I would be very happy if someone can help me.
L.
    RHEL6 is not a supported platform for IC614, and no testing is done on it. Normally that shared library would be in /lib - on my RHEL5 machine it comes from an RPM  glibc-2.5-18.i68 - maybe you don't have it because your glibc is too new?
    Also check that you do not have the $LD_ASSUME_KERNEL env var set.
    Either way, you're using too new an OS; we have supported OS versions for a reason - so it's clear what we've tested under:
    http://www.cadence.com/rl/Resources/release_info/Supported_Platforms_Matrix.pdf
