  2. RF Design
  3. Minimum beat frequency setting for PSS analysis to have...
  • Subscribers 63
  • Views 2677
Minimum beat frequency setting for PSS analysis to have smaller step size sweep in PAC,PXF
RFQuery
RFQuery over 15 years ago
 I know the beat frequency setting for PSS should be the minimum frequency of the circuit signal frequency.
But I want to sweep the PAC analysis with a step size less than my circuit frequency.  So I chnage my PSS beat frequency to the minimum step size of the PAC. But this resulted a huge difference in the transient analysis and PSS-transient analysis (tstab plot).
So is there any lower limit of beat frequency setting in PSS.
    There's no lower limit, but doing this will mean your simulation is very long as you will have many cycles of the high frequency content - and this it will take a long time and a lot of memory. I can't see any particular reason why there should be a huge different in the tstab and transient, since essentially the tstab is a transient.
    Anyway, regardless of this, it's unnecessary to set the PSS fundamental lower just because you're using a lower frequency in the PAC. I don't know why you're doing that. If it was the other way around - needing a very high frequency in the PAC compared with the PSS fundamental (e.g. above 40 times the PSS fundamental), you might need to either set maxacfreq or increase maxharms to ensure that there are sufficient points in the time domain solution at the frequency of interest, but you don't need to do anything like this for low frequencies.
