  2. RF Design
  3. how to view sweep points on Smith chart
  • Subscribers 63
  • Views 15273
dxt78
dxt78 over 15 years ago
Hello, I'm running a PSS simulation and looking at an impedance while sweeping an inductor value. I'm wondering how I can see the sweep points. For example, if I sweep the inductor value from 10pH to 100pH in 10pH increments, how can I see where the 20pH, 30pH, etc markers are? I turned on the markers, but my Cadence does not display the sweep points. So far, I only see the Smith chart coordinates. Thanks.
    It's not clear what you're doing - or which version you're using. Please can you provide some more detail (as outlined in the Forum Guidelines post at the top of the list of posts in this forum) - and a picture of what you're getting would probably help enormously.
