  2. RF Design
  3. Transient noise analysis of mixer based circuit
  • Subscribers 63
  • Views 15332
RFQuery
RFQuery over 14 years ago
 Dear all,
can anybody tell is it possible to do transient noise analysis of mixer based circuit. If yes how we can do it for the mixer based circuit ?
How it can be compared with Pnoise analysis. Which one is better ?
Kind Regards
    Yes, it's possible. You can use transient noise for anything. However, it won't be anywhere as efficient as pnoise. The benefit of transient noise would be that you can see large signal noise effects (which are not normally a problem for mixers), but the downside is that you'd need a long simulation with short timesteps to capture all the noise information. pnoise just requires you to do a PSS on a single cycle of the mixer LO, and then an efficient small-signal noise simulation after that - akin to how you would use noise around the DC operating point of an amplifier rather than using transient noise for that.
    Transient noise is a bit of a sledgehammer to crack a nut in this case.
