  2. RF Design
  3. Inductor Layout
  • Replies 8
  • Subscribers 64
  • Views 23966
Inductor Layout
Henrytqy
Henrytqy over 14 years ago
Hi guys
Recently, I'm drawing the inductor in the layout. My procedure to do this is, first drawing a ring, second convert it to polygon. But I find it is not very convenient since after you convert the ring into the polygon the width of the metal can't be changed.
Could someone know how to solve this? Or is there any other better procedure to draw an inductor and transformer?
Thanks in advance~~~
    Why do you need to convert it to a polygon? Why not keep it as a path?
  • tkhan
    tkhan over 14 years ago
    Cadence used to have a tool called Virtuoso Passive Component Designer that synthesizes DRC-legal inductors, but has been discontinued for the last ~4 years. A similar tool is offered by Helic Inc. called VeloceRF.
  • Henrytqy
    You mean keep it as ring?
     Not sure I understand what you mean. What's a "ring"? (I presume you drew a path, and made a spiral. An inductor wouldn't be a ring - so your question doesn't make much sense to me).
  • Henrytqy
    Sorry to make you confused.
    "ring"  I mean my first step is to draw a ring, a circle.(in Cadence layout window, under the menu EDIT). Then I draw the second ring which has larger diameter, and erase some of them. Finally I connect them where I earse, thus making a two turns of spiral Ind.
    It's still not entirely clear, but I think you really want either a pcell to create the inductor geometries, or one of the various third-party inductor synthesis tools on the market.
    You could also place an instance of passiveLib/spiralInd/layout - passiveLib can be added to your cds.lib using:
    define passiveLib $(inst_root_with:tools/dfII/bin/virtuoso)/tools/dfII/samples/artist/passiveLib
    That said, I don't think this is supported any more - it's not documented these days. I played quickly and couldn't make it work.
  • Henrytqy
    Thanks a lot~~~
  • kousar
    kousar over 12 years ago
    did u find solution for inductor layout in cadence? i have to layout inductor of value 485pH for on chip design. did you help me in this regard. thans!
