  2. RF Design
  3. Analysis Order in ADEGXL (IC615.509 MMSIM11 64bits)
  • Subscribers 63
  • Views 15557
dwight6
dwight6 over 14 years ago
I am trying to run a phase noise simulation (PSS - PNOISE) but the simulator is trying to run first the PNOISE analysis. How can I specify the analysis order ? I tried dragging the analysis but it wasn't possible and I couldn't find the option via the "environment" window (the traditional way.
Thanks in advance.
     This has come up a few times - we've not got to the bottom of quite what scenario causes it to get into this state.
    ADE (L and XL) no longer have the old "analysis order" field - it's controlled by the order in ADE. You can bring up the test editor in ADE XL and then drag the order around. When I saw some data which had this problem, dragging the order around in the test editor fixed it - but didn't explain why it got into that state in the first place. You can't drag them around in ADE XL itself - you need to double click on the test name and fix it there.
