  2. RF Design
  3. Finding "Spectre Circuit Simulator Device Model Equations...
  • Subscribers 64
  • Views 5417
Finding "Spectre Circuit Simulator Device Model Equations" using command
RFQuery
RFQuery over 13 years ago
 Dear All,
I was able to find spectre model parameters using the command for example (spectre -h BSIM4).
Is there any command to find  "Spectre Circuit Simulator Device Model Equations" which use the above paramters
Kind Regards
  • Ashish Patni
    Ashish Patni over 13 years ago
    Hi RFQuery,
    Please refer to the Virtuoso Simulator Components and Device Models Reference for this -
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=pubs;q=spectremod/spectremod11.1/spectremodTOC.html
    There is no command line help for this.
    With Regards,
    Ashish
    Or you could run "cdnshelp" from the command line (easiest if you pick up the cdnshelp in the MMSIM installation) and then you don't even need internet access.
  • Jack777
    Jack777 over 9 years ago
    I can't download it anymore. How can I get a new link?
  • Frank Wiedmann
    Frank Wiedmann over 9 years ago
    Try this one: http://support.cadence.com/wps/mypoc/cos?urile=deeplinkmin:TechPubDocs;src=pubs;q=/spectremod/spectremod15.1/spectremodTOC.html
  • Jack777
    Works. Thank you!
    As I mentioned earlier in the thread, the documentation is also in the software installation. Either run `cds_root spectre`/tools/bin/cdnshelp (those are backquotes - effectively cds_root is finding the installation for spectre) and look in there, or just run "cds_root spectre" to see where the installation is, and you'll find a doc directory, under which is spectremod/spectremod.pdf
    Or if using support.cadence.com you just need to go to Resources->Product Manuals->MMSIM (e.g. MMSIM15.1) and then you'll find the manual there. I thought it better to describe how to find it rather than just giving a link which will go away in a year or so when MMSIM15.1 is no longer supported.
    Teach a man to fish, and all that.
