  2. RF Design
  3. .OA to .cdb conversion in IC5141
  • Subscribers 62
  • Views 16458
RFQuery
RFQuery over 14 years ago
Dear All,
I want to see through RFworkshop library in MMSIM10.1. But in this the scematics are in .oa format. I am using IC5141.
How can I convert these .oa files to.cdb file
Kind Regards,
    You could use oa2cdb to do this - this is in the IC615 release. Note that oa2cdb is not intended for production flows - it's more of a safety net.
    That said, if you're going to have to install IC615 to do the translation, why not run the workshop in that version. It's quite possible that the ADE state cellViews won't work fully in IC5141, so it might be quite confusing trying to run in an untested version.
  • RFQuery
    Thanks a lot.
    I will do as suggested by you.
    Kind Regards,
