  2. RF Design
  3. How to do modification in BSIM3v3 model MOS equations in...
  • Subscribers 62
  • Views 15527
How to do modification in BSIM3v3 model MOS equations in Spectre
RFQuery
RFQuery over 14 years ago
 Dear All,
I want to do some modifiaction of  BSIM3v3 model MOS equations in Spectre.
Can anybody please tell how it can be done in Spectre.
Kind Regards,
    You can't do it directly, because the model is implemented in C. However, I believe there are some Verilog-A implementations of the various BSIM models "out there" which you then may be able to take and modify to suit your needs.
    Changing the model equations is not for the faint hearted - I presume you have a good reason for doing this? Can you not achieve the same end by altering the model parameters rather than the equations themselves?
  • RFQuery
     Thanks Andrew for your suggestions
    Kind regards,
