  2. RF Design
  3. hbsp convergence issue
  • Subscribers 63
  • Views 15977
Aldo2
Aldo2 over 14 years ago
I'm running hbsp simulations on a mixer. When S-parameters are calculated the following message is shown in the spectre.out form:
Warning: Insufficient norm reduction in GMRES.
Warning: Switching to the basic preconditioner automatically.
Warning: Stagnation still happened in GMRES with basic preconditioner.
Warning: GMRES did not converge to the desired tolerance of 1e-06. It converged to 0.743312. The solution may not be accurate but it's saved anyway.
Warning: GMRES did not converge to the desired tolerance of 1e-06. It converged to 0.99660473. The solution may not be accurate but it's saved anyway.
I set 9 harmonics for LO and 7 for RF with oversample 1 or 2.
Any suggestions for a better precision of the results?
MMSIM version: 11.1
Thank you very much
Aldo
    Aldo,
    I've not seen this before (and can't find a report of it either), so please contact customer support.
  • Aldo2
    Ok, many thanks.
    Regards
    Aldo
