  2. RF Design
  3. PA constant efficiency contours
  • Subscribers 63
  • Views 15301
bVenu
bVenu over 14 years ago
I am trying to do a load-pull simulation to study the optimal load condition for a CMOS Power Amplifier. For this, I use the parametric PSS simulation with a portAdapter to traverse all possible reflection coefficients (gamma) on the smith chart. After the simulation, I use the 'Power Contours' option in the Direct-Plot form to plot the contours of all the values of gamma which result in the same output power.
Is there any way I can set up the simulation to plot constant efficiency contours or in other words contours of gamma which result in the same drain-efficiency.
Thank!
