  2. RF Design
  3. mtline model "Display Cross Section"
  • Replies 11
  • Subscribers 63
  • Views 10855
sohaiba
sohaiba over 14 years ago
As you know that there is now a cross sectional viewer button in the analogLib mtline component edit properties/add instance form.  The "Display Cross Section" button becomes visible when the Type of Input is set to Field Solver. The issue is that when I click on "Display Cross Section" button the IC 6.15 tool displays "Starting Displaying" .... in the CIW but does not display anything even after waiting for it to respond. What could be the issue?
Regards
  • Eduard Atkin
    Eduard Atkin over 6 years ago in reply to Andrew Beckett
    yes, that works. I have upgraded 2 rpms (tk and tcl ones) and UI has appeared.
    Thanks.
